- Joined
- Jan 15, 2007
- Threads
- 10
- Messages
- 99
- Location
- Perth, Western Australia
- Website
- www.offroad80s.com
I have dual batteries in my 80 that runs through a 4 position marine switch (off, 1,2,both). Basically each positive goes to the swtich with the factory positive terminal hooked to the switches outlet. I have attached a quick digram of how its wired.
I like this setup because I can run every thing off the second battery which suits me just fine. Only trouble with this setup is I have to change over the batterys to the main before starting after using the aux batt. Then after a short time off letting some charge into the main, I then change over to batt 2 to charge that. I dont really like hooking them both together as they are different batts and I dont want to stuff them.
So the question is: Is there a way to run a charge wire direct to the second batt (from the alternator) so the morning after(camping that is;p ) all I have to do I switch over to batt 1, start up and dont have to worry about switching over to batt 2. And it does not interfer with my ability to isolate each battery completly from each other
before writing this.
