Dual Battery box
Tucson
I purchased a dual battery box from SOR. Since I have a 69 chassis, I had to re-route the brake line in order to fit it in (it bolts to the original battery mount stand). No problem.
Then!!!!!!!!
The SOB won't fit in because I still have the vacuum actuated 4 wheel drive on the firewall.
Any ideas???
Tim Hill has a direct shift unit he has been trying to sell me, but I don't want to go that route unless I have to.
Can you re-drill the holes to mount it a little forward? If you have the room that's what I would do. You can also lift it a bit with some spacers to clear the vacuum stuff. Otherwise...but the floor shifter.:)
Ed
Well, I bit the bullet. I am going from a three on the tree with vacuum actuated 4wd, to a floor shift and a floor shift for the 4wd. I picked up the parts today, and degreased and cleaned them up.
This achieves a couple of things. One, the battery box will fit now that the vacuum hardware is off the firewall. Two, the linkage for the column shift made it a bitch to get the headers in and out, or just to change gaskets. Three, it opens up two holes on my dash for other things, and gets rid of the lever under the dash for hi-lo range.
The down side, I have to find another location for my "junk" tray which sat on the tranny cover.
