- Joined
- Jul 18, 2009
- Threads
- 75
- Messages
- 313
lovetoski said:Hi Tony,
If you add up the amp draw during a typical winter day in the nw (headlights, heater fan x2, rear window defog, windshield wipers, stereo) it's enough to cause a pretty good voltage drop at lower rpm...ie the stock 55amp alt can't keep the system at 14/14.5 volts. Everything electrical works better at 14.5v. If you add a second set of driving lights, especially for night wheeling where you're going slower, you're pushing the limits of the stock system even further.
In my opinion, the stock electrical system is just adequate, but if you add stuff it's no longer sufficient and needs an alternator upgrade.
Also, with a desmog, the space occupied by the smog pump is available to do something with. I have a jim-c pully, and that's a much easier/quicker way to replace the smog pump.
I went this route for four reasons: redundancy, to increase the reserve capacity of the electrical system, to see how it would work, and to document the results.
Do you want to sell the Jim C pulley.
