My ds door master switch assembly started to rattle a bit awhile back followed closely there after by the front of the switch falling down inside the compartment. Upon removing the assembly I noticed the single of the three screws that hold the plate to the switch had broken its plastic sleeve that the screw goes in to. I tried adhesives and none worked so I threw this together. It is some kind of sheet metal screw the length supports the switch from the bottom and you can turn in or back it out for the custom fit
I did flip the plastic sleeve from top to bottom before I ran the screw.
