Dry engine install - prime fluids?
Pacific NW
I'm picking up my "new to me" 1fz today and had a question.
When installing a dry engine, do any of the pumps need primed?
Oil - Assume no, oil falls to pan anyways
Coolant - I've heard of priming water pumps, didn't need to on my 350, ???
Trans - assume no, I'm pretty sure this is a "pusher" pump
Power steering - ???
Hell Yes on the the OIL. If you don't do anything, Prime the oil..
Trans is the trans...Did you replace that?
Coolant.. I would fill will distilled water first. Run check for leaks, drain half and fill the rest with red toyota antifreeze.
Depending on how long the engine sat between being built and now and depending on how they lubed it on assembly, you don't necessarily have to prime the oil pump. If it was just built and the builder was very generous with the engine lube, you could probably just dump some oil in and turn it over a few times with the ignition disabled, but why risk it. If it were mine, I would definitely prime it.
No need to prime anything. I'm assuming this is a used engine that's simply been sitting around. I'd flush the cooling system with water like a hose running for a few minutes to flush any crud, then fill with coolant. Check all fluids and crank it with the coil wire off to allow for the oil and coolant to get around the block, then start it.
If you're talking about a freshly built up engine, then say so. Totally different.
DougM
DougM
Just picked up the motor. "New to me" with 150k.
I plan on replacing the head-gasket, crank seals, oil pan seal, oil pump gasket, and various other little gaskets.
Trying to stay on a budget, so no machine work or deep cleaning.
I plan to flush the heaters, the block, and the coolant portion of the radiator. I didn't think it was a good idea to flush the transmission coolers with water.
Definitely don't put water in the tranny cooler portion of your radiator. I was referring to the engine's cooling system after you've got the engine ready to go do a flush as if you just bought the car and did not know the status of its cooling system - engine, rad, heater cores all together.
As for work done on the engine, I'd consider a valve job at 150k - especially if the valve seals have been sitting and drying without use. Toyota's valve seals come with the head gasket kit from Cdan so you just need a shop to clean the head, do a valve grind to clean the seats and valves, then install the seals and adjust the valves for you. I pay $325 here in Spokane, WA for an excellent shop.
DougM
DougM
I appreciate the advice and will consider it. As valves go I assume you loose performance and get some blow by into the cam area???
There are many things I would like to do, and maybe should do, but money is tight right now and I just dropped close to $2k on a rig I only drive for wheelin' trips. ($1500 motor, $340 parts from Cdan, + fluids) I've heard buy a new radiator, new water pump, etc.
Yeah, I hear you - it does add up. The valve job isn't a neccessity. My bro in law's has 340,000 miles in it and the valve seals just started smoking at around 300k. So slight only I notice it, too. You're making good choices.
DougM
I misunderstood. I thought we were talking about a new motor. Do the maintenance that's easy while it's out and stick it in and go.
