I've been reading about 80 and 100 owners suffering from a low bassy hum or drone with little resolution. My '97 LX has had this since I bought it at 162K with new Yokohama Geolander H/T new tires. I now have 198K and I've done both driveshafts with new OEM u-joints and some hum did go away but it's not this hum. I've got a hole in my muffler but this droning sound is present when I switch off the engine at 70 mph. It's present when I roll to a stop, very pronounced at 20 MPH as you come to stop signs with the engine idling. It's very present and resonating/pulsing at 68-72 MPH. I've not replaced any motor mounts or control arm bushings yet. I'll be replacing the front control arm bushings later this week. I don't suspect it's the motor mounts as the sound is present when the motor is off and even at idle as I coast.
I suspect it's a road/tire resonance that's creeping through worn control arm and panhard rod bushings but I don't have the funds to replace the rear or panhard bushings right now.
I know the 100 series has a resonator puck attached to the passenger underbody to help eliminate these resonance frequencies present in these iron pigs but I've seen nothing about if this is normal for an 80.
Has anyone eliminated this issue with their 80?
