Driving in sand?
Glad to learn about these tranny temp numbers in high. At 18psi I have never had an issue at Sandy Neck (Cape Cod). It's happier with the center diff locked. Will try lo range next trip (once the birds have fledged and it's back open)
Locking the center diff really does help.
Yesterday I was out there, and to do a test, I went onto a flat area, disengaged the center diff, and went out into the looser sand. As I went into the looser sand, I could definitely tell the truck was bogging down and I was decelerating a lot. Redid it with the center diff locked, and no bog down. I suppose it was due to the fact that the front tires were slipping and the back tires were still on good ground with a decent amount of traction, so the front tires lost their power.
it is interesting what one can do on sand with our multiple layers of traction aid.
Start in High or better Lo, then CDL, then rear, then front, then air pressure, getting farther with every one. Trick is to leave the last one for coming back... :)
I'll happily report that I have had great fun in the sand and never got stuck. Bogged down, yes, many times, often on purpose, but never stuck. (Admittedly, this was beach sand, not fech-fech or the like...)
I'll sadly report that my (built) 80 is much better than our (stock) 100 in the sand, though, for reasons that I'm not entirely clear about and which is a bit surprising.
The 100 has one thing against it: its a stinkin heavy pig. My 3500 lb toy pickup could bounce and hop it's way over or through anything. Light on it's feet and fun to off-road with. I have never felt like I could bounce, beat, hop or otherwise with my 100. It's more of a "let's think about this...choose a solid route....and slowly crawl my way through this trail and try not to break anything
Spent the day in Corolla in OBX. The low gear/20psi/CDL adjustments did great. Kept it at 10-15mph and had no issues with 10miles of sand driving. Some speed demons ended up getting stuck in their domestic pickups, which proves the points made earlier in this thread.
No special tires are needed and it mostly plays out in the tire pressure.
Excellent to hear this. I will be taking my truck on the beach this weekend and have been wondering if special tires were needed. I have fairly new Michelin all seasons on there. I will be sure to deflate them, and lock the center diff.
I run the same tire. Air down. Lock her in lo gear an enjoy
Been on two beaches so far this weekend. Even today in rainy and super windy weather. Not a single issue. It felt grippy the entire time. Just aired down to 15PSI, locked the diff, and away we went.
Near the entrance, a park ranger stopped us and warned us not to drive up. He said:
“I’m warning you, the sand is really soft up there. If you get stuck, well, I’m on my way home, and if you call, no one’s comin’. I ain’t coming to get you out. I’ll see you in a few days... have fun!”
We went anyway. We made it all the way up, ate our dinner on the tailgate, and eventually headed back home. We were the only people there... along with a lot of seals... there were lots of seals. It was cold, rainy, and really windy, but it was a great experience, and I’m looking forward to more adventures with my Land Cruiser.
Been on two beaches so far this weekend. Even today in rainy and super windy weather. Not a single issue the entire time. It felt grippy the entire time. Just aired down to 15PSI, locked the diff, and away we went.
Can’t believe a Park ranger told u that. If u had gotten stuck he might, and I mean might make a call. Have never seen a ranger ever help someone buried up. I remember a time I had landed a “pig” and was releasing her and a ranger pulled up outta nowhere an said what a nice fish I released. Must of had his spyglass on me because there was no one in sight. Anywho he proceeded to get stuck and I proceeded to fish. He asked if I had a shovel and let him use it while I fished.
I run about 24lbs most of the time unless it gets sloppy and only once have I aired down below 18.
Carry on an enjoy
View attachment 931381View attachment 931382
I know this is an old thread… but headed to Corolla as we speak for the first time! Deflators set to 20 psi and looking forward to the trip. Appreciate everyone’s experience.
No surprise, the Cruisers a beast. 20 PSI, CDL and send it!!
Corolla is great, you're gonna love it. 20psi is a solid starting point — I usually end up going to about 15-16 on softer sections. The thing about beach sand on the OBX is it varies a lot depending on the tide and how compacted it is up near the dunes. Closer to the water it's almost always firm enough you barely need to air down, but once you get into the loose stuff further up or the softer access paths, you'll feel the difference immediately.
CDL is non-negotiable on the soft stuff. Did a lot of recovery work over the years and you'd be amazed how many people dismiss locking the center diff on beach runs until they're suddenly doing the slow diagonal drift into a hole. Triple lock the 100 if you've got it and you'll basically never need to worry. Keep your speed reasonable and momentum consistent — steady throttle beats trying to power out once you've broken traction.
If you do get stuck, don't spin the wheels — you're just digging yourself in. Stop, drop a few more psi, try to back out the way you came in. Way easier than trying to go forward.
Have a good trip out there.
