Ok, here's my latest problem, long story but should give all the info I know. I don't know the official names for some parts but will try.
Last fall, replaced right Birf (to include larger drive flange).
No problems. Drove it for miles and miles.
This winter, felt like front end was locked (I have no mods), even had the back end come around on some ice in my driveway, and occasionally i get some wheel hop when turning.
Around Feb, started getting a noise out of the right front end, eventually found the brass insert in the right front outer axle was worn and replaced it, worked fine.
In early April, I noticed some differential fluid underneath the front end. When underneath, it looked like it had coated all the way back to the transfer case. I added a quart and drove to my mechanic.
Here is where it gets crazy.
Shop manager told my mechanic that I there was another sound from left (there was some clicking or popping but only at extreme wheel turn). The machanic tore apart my left wheel, found a few bearings (the top and bottom in the knucle) that needed replaced. He also thought there was too much play in the Birf (old left one).
I had him swap Birfs (not knowing the new right one was bigger and drive flange needed swapped also) We put back together and it was stuck in right front and rear drive...put on lift and only the right sides would spin, not right rear/left front or vice versa, pulled super hard to right.
Pulled back apart and noticed birfs were different sizes, put back on original sides and it drives straight now, but.........
(also replaced all seals and bearings in the front axle)...only charged 5.5 hours of shop time as well, so I can't complain! Anyway, to the but..........
Now it feels like it is locked in front wheel drive, if you let go of the wheel in a turn it straightens out, if you hit a bump with one front tire, it barks when it lands. Basically feels like I have front drive only and that the front diff is locked (which I don't think is possible?) Only other symptom is that at idle, flat ground, no brake is needed to keep from crawling forward.
Only other maintenance is that in January we replaced brake pads and had rotors turned.
I'll send a Sam Adams
to anyone who can help me!
BTW, the shop thinks it is the center diff (side of the transfer case?) that is causing the problem, but I still don't see how that explains the front end being so bound up and straight now?
Thanks again for any help.
John
to anyone who can help me!BTW, the shop thinks it is the center diff (side of the transfer case?) that is causing the problem, but I still don't see how that explains the front end being so bound up and straight now?
John
And no, stay away from locking hubs, they're for part time rigs. Yours is full time, remember? Sorry to hear about that stump. Armor will help, but it won't make it foolproof, so ya still gotta keep your eyes open.
