driveshaft spacers
Boise ID
I was looking around and found some driveshaft spacers that go in where the driveline connects to the axle and was wondering if these work? Mine is a 72 40 with a 5 inch lift and stock driveshafts. Could i use these or lengthen the shafts or do nothing at all? If they are good does anybody know where you can get some?
Thanks Adam
With stock drive shafts your splines are probably right at the end of their travel. I dont know much about the spacers. The only down fall to them would be you would be putting a lot more shear on the bolts because it gets amplified from the leangth of the bolt. This might not be a problem for you but I have had to drill all my flanges out and put 3/8 bolts in.
The rule of thumb I keep hearing is 1.25" of in travel on your shafts. Go under and measure it If you are a lot more than that I would just heve them retubed and be done with it.
