Driveshaft slop
Houston, Texas
Before a day of wheeling this past Saturday, I was under the truck prepping and getting ready. I noticed the rear drive shaft will rotate about 1/2-3/4 of an inch. The entire shaft spins meaning the rear pinion and rear tcase output as well. That seemed a little too much but wasn't sure. For my truck, this is where I am having my "clunk". I can sometimes feel the lag when accelerating from a stop sign for example.
History- I have 197,000 on the clock. After I rebuilt the rear tcase output with new bearings and seal, about 2k miles ago, the slop was minimal. Maybe an 1/8 of an inch. I have never pulled the rear third member nor have I replaced the pinion seal or crush sleeve. No leaks from the pinon or tcase. When I had the drive shaft out for the tcase repair, the u joints seemed good and there was no slop in those.
Is this within what would be considered normal range? My guess might be that it is time to replace the pinion seal, crush sleeve and restake the pinion nut.
Thanks for any advice,
Buck Buchanan
Doesn't sound excessive? The slop is the play stack up, of the play in all of the gears, splines, etc added together. Gears (ring & pinion, spiders, transfer) must have backlash, splines aren't press fitted, have play. The important question, does it run smooth or make a whine, howl, etc noises, most of the time it will make noise if there's a problem.
Replacing the pinion seal, crush sleeve and restake the pinion nut will only help if the nut is loose, does the flange move with the nut or is it loose?
reads like several I've seen....
Kevin,
I didn't really look at the nut but I will this evening. There isn't any in and out movement of the drive shaft at the tcase or the rear diff. I do know that their is more rotation of the rear shaft than the front. There are no noises coming from the rear end or d-shaft.
I wheeled fairly hard on Saturday with no problems. What made me think there could be an issue is there is much more play now than when I rebuilt the rear output from the tcase.
Thanks
Buck
Pinion nut is tight.
I guess this amount of play is normal. Maybe it was less after the tcase rebuild due to new bearing and seal being a little more snug.
Thanks for the reassurance.
Buck
There is a lot of stuff that can affect the amount of perceived slack/play. If the tires are on the ground, it's the luck of the draw of how the spider gears are stopped, they can be at a point where there is no bind/all of the play is felt or slightly bound, touching each other, no play felt. The transfer will likely have more/less play depending the which gear it's in. The play is probably affected by axle and/or CDL being locked/unlocked, etc.
To make a comparison it's important to have the wheels off of the ground and the shifted configuration the same, but even then it's not a precision thing, more of a check to see if there is way too much play.
I'll toss her on some stands this weekend and take actual measurements. I truly appreciate the knwoledge you impart into your posts. I always seem to learn something new from you.
Buck
If your only checking the diff, putting the transfer in neutral takes it out of the picture. It's probably a pretty much pointless test if it's running quiet, most times if you have a diff problem you will feel and/or hear it.
Well now, looks like I'll have to find something else to do. Who am I kidding, a 3 and 1 yr old, I already have things to do. :D
Many thanks
Buck
