Driveshaft Rotational Play
SK, Canada
Hey,
Trying to track down a loud whining noise I‘m getting on deceleration from higher speed (anything over ~70kph). Could be occurring during acceleration too but less noticeable if so. Almost sounds like loud straight cut gears, shifting trans into neutral during deceleration makes it disappear.
Pulled front driveshaft with locked cdl and there was no change.
Inspecting the rear driveshaft I do perceive some play. Specifically rotational play in the slip joint. My question is - what is normal? Driveshaft is freshly greased, but I didn’t pull it apart to grease it thoroughly. Next step regardless will be pulling rear ds and going for a drive, but curious what people think. Also have a set of chassis ears on the way.
Doug, I’m in nearly the same boat. I discovered my rear ds was bent, but with the truck on the lift, I was able to isolate most of the noise to the t case. My guess is that vibes from the bent ds are causing something to shake or shook something completely loose in the t case. Anyway, I have replacements for both components. My plan is to replace the ds first and see if that fixes the noise and then replace the t case if not.
All that to say, it seems like your thinking checks out with my experience.
I didn’t get that far. Noise was present with front driveshaft pulled. Chassis ears narrowed it to rear t-case area and I could feel some play.
My bad, I read wrong.
