driveshaft lengthining
Boise ID
I just got done lifting my 72 fj40 about 5 inches and i was reading and have recieved some information that I might need to get the driveshafts lengthend and I was wondering about how much ( like an inch or tow) or jsut buy new ones
thanks
thanks
The proper way to lengthen it is to re-tube it. Cheaper than buying new ones.
Plan on about 80 to 125 bucks. You mileage will vary. I'd spend the extra $$ to have it balanced if it is for the rear.
Depending on your lift, and if you did a shackle reversal, you may want to get a new front shaft built that has a longer travel slip yoke - they can come apart, mine does all the time.
Rear shaft may be okay, I only added a small amount of length when i added the mini CV in mine.
Easiest and cheapest is just have it re-tubed or buy new ones and keep old ones for trail spares, that is if they fit at all and have enough spline engagement to be servicable.
