Drivers window goes down but not up
Seattle Area
I have a problem that I think is fixed by replacing the switch panel for the drivers door but Id like confirmation before I order one. My drivers window goes up and down if you move it a little bit. If you ever let it get all the way down then the window will not go back up. I have confirmed that the motor does not get power to it in this situation. I have jury rigged it for now by placing a wood block inside the door so the window can not go all the way down.
Think this is a door panel switch problem?
I have same problem with my '94. It's worse in wet and cold weather - window movement is also slower. I removed and cleaned track which has seemed to help. I would concur on the switch diagnosis, though. Drivers window only has one switch in circuit and that's the master switch. If no power - it has to be the switch. You might be able to disassemble and clean contacts in switch. It will help unless contacts are pitted.
I am thinking its more in the switch circuit board than the switch because I removed the rocker parts so as to expose the switch portion. I can watch as a spark jumps across the switch when it is re-opened. I did clean the contacts but it didn't help.
Recommendations on where to source a used/good '94 switch?
