Hey, I have a leak down the side of the dash on the driver's side. See pic attached. It comes from between the black part and the grey part. Any idea where it can be coming in from? It seems to come in from snow melt and not rain. Thanks much.
.... Check under the moulding at the top of your windshield for any deformity or indication or rust. Any at all should be remediated immediately to ensure the windshield seals properly and has a decent surface to do so. The rust, if there, will only get worse and should be dealt with.
Ask me how I know![]()
??? Aren't there 4 drain holes. I can easily see the front 2 how about the 2 in the rear. How do you get to them??I had the same leak...it was the drain holes in the sunroof. I took a straw and stuck down the hole and blew out with air compressor. No more leak
I only did the front 2??? Aren't there 4 drain holes. I can easily see the front 2 how about the 2 in the rear. How do you get to them??
