Driver's Door Opening Sequence with Opposite Effect
Oman
Hi Everyone,
After experiencing a battery power loss, I had to reset certain settings. Following the reset, I noticed that the door open/close sensor on the handle is behaving differently.
Currently, when I touch the door sensor on the driver’s side, it unlocks only that door, whereas touching the sensor on the passenger side unlocks all doors. This behavior is the exact opposite of what it was before. Does anyone know the remedy?
Appreciate you support
Regards
Kamal
On my 2013 LX, these settings can be configured in the on-screen. "SETUP"--> "VEHICLE" --> "VEHICLE CUSTOMIZATION" --> "DOOR LOCK SETTINGS" menu.
The setting you are looking for is under "Unlocking Operation", and is "All doors unlocked in one step"
Alternatively, TECHSTREAM software can be used to change these settings on most models. Unfortunately, some functions may or may not be available depending on the model year of the vehicle.
Thank you. Unfortunately, my model does not have the onboard display unit. I do vaguely remember that it was a sequence of keys from the door switches which I have not been able to sort thus far.
