I searched around but haven't found a thread relating to my specific problem. I also searched the FSM but couldn't come up with an answer.
My drivers door does not seem like its connected to the power lock system. The master switch will lock the other doors (3 passenger and the hatch) but does not unlock the drivers door. Also using the key in the drivers door will unlock it but none of the others. If I use the key in the passenger door I can unlock the rear doors and the hatch but obviously it has no effect on the drivers door.
It seems like there is a harness or something that isn't connected that is causing the drivers door do be disconnected from the rest of the system. I haven't taken the door panel off because the particle board like material is cracked and fairly weak and I would prefer not to take it off more than necessary.
Has anybody else run into this? Is it simply a harness or a dirty contact and an easy fix?
