Okay, long story short, 2005 gx 470, I believe the wire from the amp to the mark levinson woofer is broken someplace. I replaced the door harness, the amp (there was a gx470 in the junkyard so it was an easy swap) and tested the speaker (good). I assume the break is from the woofer amp output to the door plug. Does anyone know which pinout it would be, I feel like the easiest solution would be to run a single wire for this. I'm not the best with wiring diagrams, so a photo with an arrow to the plug would be great.
