[Solved — the window guide was blocking the mechanism. Now to figure out where that is supposed to be...] Hi MUD - Hoping someone has solved this one before. The latch on my driver side door won’t release using either handle. I took the panel off and everything looks like it should. And I’ve tried prying the match up as I pull on the interior handle but no luck. Anyone run into the same issue? Thanks!
