Driveline noise/vibration
Texas
Good morning all!
I have a 2008 4Runner with 200k that developed a vibration and noise from 20mph+. The noise/vibration started out of no where in traffic. Noise/Vibration is RPM independent and is present whether in drive or neutral (under load or coasting). I would almost describe it a a roar from the rear dif. Strangely, the noise and vibration disappears when making a right turn, but is present when making a left turn.
To test, I removed the rear driveshaft and drove up to 60mpg. In FWD mode, there is no noise or vibration under load/acceleration however is present under deceleration(engine braking).
Front/rear drive shafts and ujoins have been greased and are tight. Both rear outer rear axle bearings have been replaced (fluid replaced as well). Dif pinion does have a small amount of backlash, but nothing more than what I'd expect from a 200k rear axle.
I installed a 3" lift in late december. I replaced LCAs, UCAs (cheap KSP uppers), front/rear sway bar linkages, ball joins, Bilstean 6xxx fronts, 5xxx rears. The driver CV joint had a bad habbit of self-disassembling when left hanging (I anticipated replacing both CVs and front wheel bearings later this year fwiw.) Wheels and tires were balanced by a low end local shop.
I can't think of anything else to add, but will answer any questions if someone has an idea.
I have a very similar issue in my 2005 GX. Vibration that comes on around 20MPH that is speed dependent, but I think it's coming from the front. Goes away when I turn even slightly right. It's not the tires, and I've been to an alignment shop twice. Did you ever figure out what was causing your issue?
