Driveline flange question.
Sacramento Ca
Found a mini truck shaft I'm going to pick up in a hour or two, and having the DC joint installed into my rear driveshaft to kill the vibration. My question, ate the flanges/bolt patrers the same between an 80 and a geared case from a truck? IIRC the truck flange is a bit smaller, but if anyone knows offhand, it would help my days' adventure on the parts scouring 101. If its much smaller I'll need to find a different flange, otherwise have it drilled out at a machine shop, as my drill press can't do it at the moment. (That new drill press is looking even more useful, maybe I should buy that too while I'm out...). Thoughts? Ideas? Thank you!
This might help. Thank cruiser outfitters. The number in the upper left bolt hole is diameter of bolt used.
Oh yeah, buy the drill press :wrench::wrench::wrench:
Having my freshly built driveshaft cut and install the DC joint, running it on the tcase end. Don't it many times with pickups and 4runners, but not with a LC 80
