DRIVE TRAIN/TRANNY ?'s
Arizona
I dropped my front drive shaft today and locked the CDL. I will be working full time and going to school full time all this year and will do about 18,000 miles. I dropped the drive shaft to help with MPG and reduce wear on the birfs. Can I run the truck like this all year with no problems with the drive train?
I also noticed that I now no longer have the clunking noise when I take my foot off the gas nor do I have the terrible slamming of metal noise when I shift to R. I assume this means I had too much slack in the front drive shaft.
My last question is regarding tranny drain and fill. Do I simply drain from the plug, then fill from the dipstick? How much ATF do I need to add? And how many drain and fills do I need to do to get all the old stuff out?
I dont believe dropping your front driveshaft will save the birfields. Assuming you had full time 4 wheel drive?? You probally have full time engaged hubs, so in that case if your wheel is turning your axles are also turning.
This could get you some extra milage however...I have never tried it...
It won't hurt anything. I doubt you see any big MPG gains though.
Yes it will help the keep wear on Birfields to a minimum as there is no load on them anymore. The slack is from all clearances in the drivetrain. You have alleviated 1 of 2 areas that cause bind, so you should have less clunking. You can flush the tranny, but with lots of miles I would think twice about that. A couple of ATF changes will be enough to make sure its clean although 1 has always been enough for most people.
Do I just fill from the dipstick?
Look up the "Rodney Flush' for that A440 transmission. That would allow you to get all new fluid in there without the risk of a chemical flush. It's pretty easy, takes about 20 quarts of fresh ATF. There has been lots of discussion here.
Second best would be a drain/fill that will take roughly 6 quarts. That would be better than nothing, but not as good as the exchange you get with the Rodney method.
Not slack in the shaft, but play in all the meatal junctions between the t-case and hub flanges.
Also,
Without installing locking hubs on your front axle your not stopping anything from turning. You're still going to wear through those oil seals and such at a 'normal' rate. You may reduce wear on birf's as Gary suggested- but I've heard no evidence to this.
FWIW, I removed the front drive shaft AND installed locking hubs (leaving them un-locked) and noticed LESS than 1 MPG gain even in freeway driving.
Thanks guys. Im going to leave the front shaft out for now. As long as Im not hurting anything. I'll see if I get any better MPG. It handles like crap and no longer has that "TANK" feel when driving.
I noticed something weird last night. While stopped at a light I began to shift back and forth to D and R. I noticed the truck seemed to lower when shifted to R then raise back up when shifting to D. Almost like a lower rider with hydrualics. Weird
You were loading your suspension using the drivetrain.
Bad thing, good thing, normal?
Thanks
