Drive Shaft question
Hello,
I've got a 79 FJ 40. It was a project I bought from somebody else. I've done a sbc 350 conversion and yesterday I finally got the engine to running.
I was hoping to connect up the drive shafts to where I can now move it around under it's own power.
The problem is none of the "yoke plates" on the drive shaft seem to match up with the plates drive shaft plates coming out of tcase or axle housings.
On the back of the tranny, there are actually four bolts and none of the plates will fit. They plates on the drive shafts look kind of rectangular so I've tried all different combinations.
I went on ebay searching for some drive shafts and the pix of some I found look exactly the same.
The only thing I can figure is the guy I bought this off of possibly put some drive shafts in from an earlier model. But I would have thought the bolt patters would have all been pretty much the same.
Can anybody verify this to be true.
The drive shafts are kind of dirty but is there anyway to tell what year model the drive shafts are from?
P.S. I've done a 350 sbc conversion in this vehicle. Before I waste time trying to track down FJ drive shafts are getting these to work, I'm wondering if there is some other problem I'm going to run into to where I just need to get some custom ones made? Even though the plates don't match up, the length and everything seemed to be right. If anybody that's done this conversion could chime in as to whether I should just go for custom ones versus wasting my time with the stock ones, I would appreciate it.
Thanks.
Hello,
Thanks.
Do your shafts have Double-Cardons?
Thanks for the replies, I'll investigate all. Mark, I don't think so. Not familiar with double cardon's. The "plates" or flanges if that's what they are called on the drive shafts I would guess by the way they look are stock.
The axle and the flanges on them have been cleaned and painted black so I can't say but they look normal.
I'm going to check out the websites and if I don't find anything, this weekend I'm going to try and measure the holes.
Another thing I just realized is I stuck some 32" tires on it and I'm probably going to have to do some kind of lift. Probably go with a 3 or 4" so I have to investigate if that's going to make a difference in the drive shafts I go with.
Thanks.
