Drive flange stud removal ?
So Cal
Today I re-torquing my axle hubs after I serviced my front axle last week and when I was putting the drive flange back on I snapped one of the studs :doh:
I searched this and found that I should use vice grips to remove the front drive flange studs. My question is do I just clamp down on the stud reverse it out? and does the new one just thread back in? thanks a lot, Anton
Yep, and yep- if there's enough stud to get ahold of with the vice-grips (or a stud puller, if you have one). A stud is just a double-ended bolt with no head.
Yes, get a couple new ones from your local toyota stealership.
Thats what I was hoping. thanks a lot for the replies :D
You can also double nut the stud to remove or install it. Well stocked hardware stores will carry jam nuts (thin nuts) that make this easier when you don't have many threads to work with.
Nah, I'd avoid vise-grips, never had much luck with them, always seem to slip off. I've had more luck with either double-nutting like breathed mentioned, but more likely a stud remover. Little suckers just grab onto that stud and twist it out.\
Thread the new one in with some loctite using the double-nut technique -- wait, first run a tap down the hole if you're so equipped.
Where are you in SoCal?
Dan.
Dan.
The stud snapped at the threads so I cant double nut it. So which type of stud puller do I need I searched at sears and they have 2 kinds one looks like a socket the other one looks kinda big? Which Loctite is better red or blue? Im near LA in Whittier.
Thanks , Anton
