I've got an oil pan drain plug that leaks. I replaced it and the gasket with OEM. Still drippy.
I am starting to think there may have been something on the surface of the oil pan gasket surface. Maybe it was fibrous and maybe it wore off.
Anyone know if I should have something important on the oil pan drain plug surface? Right now, the only thing between the plug and the pan is an oem gasket.
Thank you kindly.
Josh
Thank you kindly.
Josh
