What a mess!!!
I found the drain bolt on the right side of the block (I have an early 1998 V6) but no nipple on which to fit a drain tube...
So I said hellwithit and drained the coolant into a plastic wallpaper tub and 3 other catch-pails.
I did see a hole in the block immediately below the drain bolt. The hole points downward but I didn't see any threads in it 'cause I didn't have good enough lighting or eyes.
My question is, is that hole threaded and if so, with what threads, and if not, what size rubber tube could be jammed into the hole for drain purposes???
