Drain Slit Mod - Enlarge Holes?
I've determined my sunroof drain slits are not draining properly, due to mud being on and in them from some mud runs. It looks to me like those drain slits are quite small and prone to blockage. Has anyone enlarged them by running a small drill bit up in there? Like a quarter inch drill bit? I'm not seeing a good reason not to do that. If I do drill them I'll use a small paintbrush to try and coat the holes with paint, but I'm in SoCal and not that worried about rust. The truck is rust free, never had rust issues with this rig.
Thoughts on my proposed fix?
Thanks
Russ
Why not go larger and get plastic plugs that you can pop in and out for them. The rockers already have larger plugs, but the doors could use some.
STOP DRIVING THROUGH THE MUD!!!!
This is IH8MUD after all......
I recommend POR-15 for the rust prevention....
