so i went out at night started pulling fuses and constantly checking to see if the cable sparked when i put it back on the terminal, it happened to be the radio (i believe) that was draining it. However theres two wires that power the radio and one is a constant and one is triggered by the ignition. so therefore there should always be a little spark because the stereo is constantly drawing a tiny bit of power from the battery.
is there a less primitive way to check a drain? instead of pulling fuses and checking for sparks? can i do this somehow with a multimeter. because i just don't' think a radios constant wire should be enough to drain a brand new optima within one night.
could the voltmeter in the truck drain it to?
when i wired up my ignition with the EZ harness, my ignition switch didn't have a spot for acc. so i wired it up to a separate switch so manually can turn it on/off. Can you have a drain through the ignition?
