Drag Link removal
Richmond, VA
Attempting to rebuild the passenger side drag link. Now how the heck do I get it off?
The castle nut won't come loose because the ball is turning. It wouldn't pop with the pickle fork and 3 lb hammer....
Dang guys I'm close to just cutting the ball off with a sawzall.
Toss me a bone tonight and help me out guys!
I pulled the cotters and found the "screw" head at the end of the drag link/ relay rod end. Can I just loosen it and get the ball to pop out?
You can take the joint apart with that screw. IF you do that and then put a 5 pounder against the draglink *right* next to the nut, then give the top of the ball a couple sharp whacks with a ball-pien or a 2 pounder you should be able to 'set' it tight enough to back the nut off.
Doood, we coulda told ya just to get new ones...
Find a set a Japanese 555 brand ** Don't get the Chinese versions ** ... about 70-80 bux for both TREs and drags.
Or the Joint Fuji at SOR are OE quality, but around $160 for the set.
got the drag apart but the ball and castle nut are still attached to the tre. Can not get that dang castle nut off. I even put a small pipe wrench on the ball and it just spins and spins.
Any ideas?
either a Die grinder, Sawzall, or a good air hammer and split the nut. if you can cut the nut the stud should fall out.
I was hoping for a sane solution... but I am so ready to just take a die grinder to it! I actual got the sawzall out but I didn't have enough room to get it straight!
Did you try tightening it in the tapered hole yet?
The pin may not be so hard, but the ball will be pretty hard to resist wear. I'd be surprised if a pipe wrench could get a bite on the ball.
I would like to think the weakest link would be the castle nut. everything else is pretty much hardened steel.
