Drag Link Adjustment
Olympia, WA
Hi all,
Since installing the PS in my cruiser, the steering wheel has been a bit off center. Is this adjusted by changing the lenth of the drag link or do I have to pull the steering wheel :mad: to make the change?
Thanks in advance fot the advice.
Best regards,
Thanks metalonmetal! That's what I thought...just wanted to make sure!
i have to do mine pretty soon, i can't signal my right turns. before you do anything, get out and look at the drag link while you or someone else turns the steering wheel. it'll give you an idea of which way to twist.
I had the same problem when i put PS on mine... I adjusted it as much as I could with the drag link, but ended up having to take the wheel loose and finish the adjustment.
What I am concerned about, though is that the gear box is not "centered" in it's travel. It may not make much difference, but I had to tighten (shorten) the drag link until it wouldn't go any more and I won't have any more room to adjust things as they wear.
What I have thought of doing is to put a piece of cardboard or paper behind the pitman arm and mark the limits of rotation of the gear box with the drag link disconnected, then figure out where the center point is and put the steering wheel on straight at that point. Then adjust the drag link to get the wheels centered with the wheel in the center position.
Does this make any sense at all?
I may be over analyzing things and this is really not an issue. If someone can shed some light on this, I would appreciate it...
It makes total sense to me. It's important to have the pitman arm centered on the splined shaft's rotation.
Makes sense to me too. Otherwise you can end up with different turning radius for left and right.
My PS adjustment "gymnastics" included long straightedges fastened to each brake disc and a magic marker to mark the floor at full stop in each direction. The Pitman arm is not centered in the gear box travel; it does give equal throw each way though.
