Doors Unlock when Turning?
Nashville, TN
My truck (1996) is basically a trail rig and I don't drive it much. However the past few months when I do drive it I notice the following, very intermittently:
  1. Start truck, doors lock as expected.
  2. Drive normally.
  3. Turn a sweeping corner (like a left turn), doors unlock.
I don't even know where to begin! I don't really care THAT much but I have been experiencing a power drain issue over the past year or two (keeps flattening batteries), so I'm starting to think there could be some relation since they are both electrical.
Just take the doors off, problem solved :)
Is it just left turns or right too? Use a VM and pull the fuse for the door lock, if it drops, you found your drain. I'd start checking wires ensuring they are not frayed and are grounded. It could be a loose wire that touches metal on a turn.
This was happening to me , plus my dome light would flash on and off in turns and over bumps.
Turns out it was my doors not being in adjustment.
So I adjusted and tightened my door closures and it all went away.
devo
I don't know offhand. I feel like its sweeping lefts. I pulled the door card and looked at the control box and reconnected it. All looks good and snug though.
devo
I did have issues with my dome light due to the rubber cover coming off the door ajar switch effectively shaving a couple mm off it and causing it to light on left turns. Would the door ajar switch also cause the doors to unlock?
It's the door switches. Start with the doors on the right side. This is actually a documented issue. A number of folks report the doors unlock when turning left.
Take apart and clean/replace the door push button switches.
devo
How did you adjust them exactly? I have this issue. I temporarily remedied it by taping a quarter to the door so it makes better contact on the switch. lol
Resurrecting an old thread here as this issue just happened to me as well. I'd been battling the flickering dome lights ever since I picked up my 80 a year ago. It started with just flickering on large bumps, but after doing some door sensor and dome light work over the past couple of weeks, it got so bad that the dome light was on about 50% of the time and upon harder left turns, my doors would unlock!
After finding this thread, I started investigating and found that the front passenger door was the culprit (I could push on it from the inside and get the dome light to turn on). I couldn't figure out any obvious way to "tighten" the door closures as @devo had mentioned, so I just decided to flip the latch on the door jamb. Voila! it appears to have solved my woes. Hope this helps someone else, as I always appreciate having a one-minute solution to try before digging deeper and pulling the whole door apart.
