Doors don't unlock
1997 FZJ80
My passenger door lock was not working unless done manually so I pulled it a part to check the motor etc. Cleaned the motor put everything back which didn't fix anything but now none of the doors unlock when I hit the unlock switch on the driver side or passenger side. The switches work when locking but not unlocking. I have to use the remote to unlock them.
While I was working on the door I did remove the battery to replace my power steering pump and finished the door afterwards. Would pulling the battery effect some kind of setting? Maybe I pulled a wire somewhere when I worked on the power steering pump (also replaced most of my hoses)? Or would messing with the passenger door motor/connections affect the driver door switch?
My driver side switch was working perfectly before any of this started. So frustrating...any help would be much appreciated.
Thanks.
