Door Swap
striker on the later doors is recessed into the pillar so they won't work on the earlier bodies unless you modify (cutting)
I am pretty sure that you can, but you have to move the striker in a little bit, which can be done by simply bolting a peice of flat steel to the existing holes, then bolting the striker on to the peice of steel inset a bitfrom where it was.
clear as mud?
search, I and others have asked this question somewhere, but I haven't gotten a chance to actually do it.
I tried it on my 74 with 77 doors and no dice.
I'll have to look at it again but I remember the striker for the 77 being too far toward the cowl when mounted on the 74. this prefented the door from passing the striker. It made the opening too small.
I'll check again tomorrow
i have done this a few times you cant use the old striker have to use the one with the door your using mounting the striker is the hard part i have cut the door post off the newer truck and welded it on have weld ed part of it on and have made an adapter plate to bolt the new striker on and have welded the striker on its your choice the newer doors sure are nice truck also seems quiter hop this hels
Trust me on this it can be done, it was the easy thing to do just make a new striker. The only problem would be if you had a full roll cage the newer door is wider inside and may hit the A pillar of the cage.
yup it can be done with modification.
I took some pics today to illustrate the issue.
the later model strikers have the ends of the hoops sticking out from the mounting side. The late model bodies have a groove in the pillar to account for this.
I mounted it again, and re-tried my late doors.... the striker hits the door and won't let it close. This is what I remember but I forgot it was because of the hoops poking out the back of the striker.
see below:
also, the mounting holes are definitely farther inboard on the later models. for interest sake the outer striker loop looks like it should be right in the centerline of the earlier tub mounting holes :confused:
A custom striker should let the late model doors work with out issue's
It works, it was done to my 75, factory soft top, late 74 tub, it looked kinda rigged with the late model striker welded to the early tub, but it did work, would have looked a lot nicer had the PO sectioned in the late model correct post, going back to the early doors as it took a hit in the drivers door by a 10 wheeler, had to cut the door off and need to replace the quarter section now.:cool:
