Door Locks Gone Mad!
Round Rock, TX
Yes, I tried the search function. :flipoff2:
The power door locks on my '97 have become possessed! They now lock themselves randomly and sometimes continuously (10 - 15 times in succession), mainly when the key is on, but sometimes even when it is off. I tried cleaning the contacts on the switches and no luck. It will even continue to do this with the whole assembly removed. I read in one thread to check the latches and strikers on the pillars, no luck.
I have the factory alarm system, but have never used it (need to call C-Dan & order a key fob).
Any ideas? This is starting to drive me nuts! I cannot think of what would have triggered this (didn't remove the battery or anything) and it seems to be totally random. HELP!!!
the first thing that comes to mind is that either one of your doors is loose (i.e. the striker) or the main controler (the door lock "brain") is hosed. I had a frayed wire in mine when I first bought mine that caused it to do something similar. Mine was repaired under my certified-pre-owned vehicle warranty...so I don't have the specifics of the repair -- lexus replaced the entire module and replaced the section of the wire harness in question.
I know the 80 series locking mechanism wants to prevent you from locking your keys in the ignition, so if you're key is in the ignition and you try to lock the doors with the door-lock-switch, it'll automatically unlock the doors.
Methink that yours goes into a "don't lock your keys in the ignition, you idiot" cycle for some reason.
Sorry...not very constructive...but maybe it'll be somewhat helpful...
If you're getting an occasional "door open" light on your dash, you need to adjust the appropriate door striker to keep the door closed tighter. You can push out on the doors to see if the "door open" light comes on when the latch is forced to it's limit. Don't forget the rear hatch.
I am not getting a door open light on the dash, just repeated locking of the power door locks. If the drivers side door is open and the key is on, then it will go into un-lock mode, but the rest of the time it is trying to lock me in.
I like the re-boot idea!
So I guess my options are either it is something in the alarm, something gone crazy with this don't lock your keys in the vehicle mode or just some randon short in the electrical system?
I had the same symptoms in my truck. It turned out to be the switch that electronically unlocks all the doors in the drivers side door when using the key. This switch is connected to the door tumbler/lock. I unplugged the switch and all is better now. The only downside is that my doors will not all unlock if I use the key to unlock my door. Seeing as I always use the key fob to unlock the doors this hasen't become a problem.
So in my case it was a bad switch.
So did you just have remove the drivers side door panel and disconnect the switch?
I will check it out and may have to add that to my C-Dan shopping list. Hope he needs more dog food!
Is the 97 FJZ80 door lock system the same as the 97 LX450? Just curious so that I'll know what to do when things go crazy in my LX. I have only had the wierd occurence of my truck unlocking itself. I'll come back to the "locked" truck and use the remote to open it, only to find that I just locked it.
Yes, it's the same system.
What I think is happening to you is different.
Tell me if this is what you do.
1 - turn off ignition.
2 - open door
3 - exit
4 - close door
5 - lock via remote.
Yes?
If step 5 happens too soon afterr step 4, you'll hear a beep, but it's not the standard piezo beep. You think you heard the regular beep indicating that you locked your doors, when in actuality, you didn't.
You return to your still unlocked vehicle, press the button on the remote (thinking that you're unlocking it), but you end up locking it.
Go out to your rig and try steps 4 and 5 repeatedly, you'll find that on some occasions you will hear a different beep.
:D
Same thing used to drive me nuts until I figured it out. ;)
Follow Doug's instructions above.
I've had the same thing. For me it was my remote getting stuck, had to beat the remote on my sliders from time to time to get it to stop.
-Matt
Thread revival, again:
Any update on the cure for this? I am still battling the same thing.
what's happening and what have you checked so far?
Well, the same thing was happening to mine, however, after taking out the door switch/accuator and cleaning it it stopped!:)
The locks are actuating on thier own. Always locking never unlocking. On our sloped driveway the problem is worse. Fireroads result in almost constant actuation.
The remotes seem to actuate the locks properly, most of the time. When the truck locks its self pressing the remote will set the alarm. Sometimes it will actuate the lock and set the alarm and sometimes it will just set the alarm. The second scenario is frustrating because if the truck doesn't "auto lock" the alarm is set and will activate if you open a door. So the options are:
Auto lock, no remote = locked no alarm
Auto lock, remote, no lock, alarm set = locked w/alarm set
No auto lock, remote, lock, alarm set = locked w/alarm set (normal function)
No auto lock, remote, no lock, alarm set = unlocked w/alarm set
In all cases a second push of the remote will unlock and disarm the alarm.
I pulled the original switch panel and cleaned it up, no good. I replaced the switch panel off a truck on it's way to salvage, no good. My next step will be to open the DS door panel and trace all the wires looking for shorts or ground issues. I am tempted to order a control modual to put it in while I have things apart.
Yesterday afternoon the truck was sitting in the drive locking itself repeatedly. There was noone in or near the truck. The remote was at the back of the house so the remote was not the cause.
Baffeled...
This happened to me a few years ago, the car locks had done this 'cycling thing' before but I had not found the problem when one day I jumped out of the car at a set of traffic lights to grab a flyer stuck on the windscreen. The doors started to do the unlock/lock thing and stopped at locked. Now I am outside my running car with all the doors locked. :o Eventually a guy with a truck came along and lent me a long cane which I slid through the tilted sunroof and opened the electric window.:)
Out of pure frustration I walked around every door ancluding the tailgate and slammed them real hard (read REAL HARD!!:mad:) and the car never ever did it again!:)
Why I do not have a clue?:confused:
regards
Dave
Dave,
I feel your pain. I got out of the truck and left the keys on the seat. The door swung closed and locked, with my two yo twins in the back. They were not quite tall enough to reach the locks while strapped in. Fortunately I anticipated the problem and put a hide a key on the truck.
As soon as I get my front end back together I am going to restart on this issue again.
Update:
I pulled the door panel last week. I pulled all the connectors and the remote lock comand unit. I didn't find anything suspect so put it all back together figuring I had to buy a new comand unit.:mad:
End of problem! There must have been a loose connector that caused the problem because the problem is gone!:bounce:
I had the same - I just disabled the automatic locking feature and never looked back.
