Just got back from a mild ride in the woods and when i turned the car off my door locks all of a sudden started switching back and forth between lock, unlock, lock, unlock. This just goes on until for some reason it slows down and then stops. No set number of times. Any ideas. Thanks in advance. Its driving me insane.
Had a similar problem a couple of months ago and then the unlock/lock function eventually totally froze: nothing worked or moved ! Was trouble shooting everything and eventually found that the door control module, located inside drivers door, had gone bad and shorted out. Looks like water had worked it's way inside over time and the circuit board had corroded and shorted out.
Mr. T wants almost 300 for a new unit but I found a 'used' unit out of a salvage yard for $70.
Do a search for power locks, you'll find several posts with similar issues. I had a problem like this - but it ended up being an issue with an aftermarket alarm window trigger.
Check all the door closed switches. Some of the similar posts indicate that this issue can be caused by a faulty ground in the back hatch area.
Wow, deja vu here for me and my old 4Runner. Water continuously worked its way into the module and sweated the whole inside with condensation. It obviously started long before I became aware of it so it had new condensation as well as old corrosion throughout. I "threw the dice" by soaking and sloshing the switch in some electrical parts cleaner for a few seconds and then used some electrical lubricant both made by CRC if I remember right. The switch not only worked again it worked better than ever. You might try this if you find that the switches are corroded. Also as tirewater stated it can be alarm related and those various shorts or sensors can also cause this. I know its "old fashioned of me" but I regularly shoot a shot of lubricant like TC11 on all those things just to keep em lubed and working well. Eliminate that easy stuff first and then if the problem persists, start looking for other shorted out sections of wire. Hope that helps.
After you check easy things like door closed switches, remove the driver side door switch cluster. It pops off with a tug on the front of the switch panel. Unplug it and look at the connector connected to the switch assembly. There may be some corrosion (greenish fluffy stuff) in between some of the contacts - shorting things. If so, you can remove the connector housing (small set screw) and use a wire brush to clean things up.
If that doesn't help, you can take a look at the door lock control module behind the door panel (as stated above) to see if it needs cleaning as well.
Mine did the something similar for quite a while. In my case it would lock itself, randomely and regularly. After reading all the thread I could find and starting my own thread on the subject I took action. I pulled the door panel and checked all the connections. Put it back to gether ready to call cdan for the control module and it never happened again. Guess there was a loose connection that I randomly fixed.
