Trying to troubleshoot my rear latch lock actuator. I have taken apart cleaned and regreased with silicone grease. The motor spins but very weak.
Got the multimeter out to check power to the motor. Not sure what to expect. Can someone fill me in as to what I should be reading off of the blue/white and blue/red wires?
I am assume power and ground switch depending on direction the lock/unlock switch is pressed?
Found something interesting. Did a continuity test from each wire to the frame. Both wires have continuity to the frame. So thinking one of them is ground and shouldn't be thus bleeding off some of the voltage.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
