Door glass
Bradenton, FL
I would like to change glass in my doors from the vent type to one piece. Other than sourcing the glass and felt, what else would I need. Do I need new guts for the crank assembly or can I just extend the glass support for the longer window? My vents leak like they arent even there and finding replacement rubber here is next to impossible.
Sounds like you have the earlier doors. The driver's side seal used to be impossible to find in the US. I imported mine from Australia. If you can't find the driver's wing window seals, you may try the following. I was told to find the passenger seal and reverse it. It will supposedly fit and seal, but you won't be able to open the window. Not a great solution, but since you are in the middle of your Green Season, it may be better than nothing.
I would think fixing the vents would be cheaper, about $80.00 US plus the ride from SOR. If you are set on the one piece windows, try finding a pair of newer doors.
