Door flare brackets
Charlotte, NC
The rear door flare brackets on Project Griffin is rusted and one of the rivets is missing on each. The door skin is bubbling behind the bracket, so I will have to remove and treat.
Triple question:
Did anyone remove their flares and have some of these brackets?
How do I remove that rivet? The outer ring seems like aluminum, but the inside is a hard metal.
What do I use to replace the brackets with? A nut/bolt will not fit. I am not sure what kind of rivet this is.
Not sure what that is either, but it drills out ok.
Then used standard rivets to re-secure the bracket to the door. It's held up so far after 2 years or so.
Gerhard, I have the rivets. They are standard (metric) aluminum pop rivets, although you can buy them singly, for a dear price, from Toyota. They're listed on the parts lists for the door "over fenders".
I may have the bracket(s) on the shelf. LMK if you need them.
