Doohicky update
'Bout time...:grinpimp:
Jack
The 80 locker switch made a clean install. It looks factory.
I went ahead and added a relay that supplies both the pump and the solenoid in parallel, so there will be a delay before the locker engages. But I don't see that as an issue.
The delay should only be on the first engagement right? Once the compressor is pumped up, then the locker should engage fairly quickly after that. Or will the relay cause a delay any time?
Jack
Dan, how's the air hose to the doohicky???:D
Let a guy pinch an air line one time and he can never live it down. :rolleyes:
:grinpimp:It's good, I took special care routing it.
Jack
Sorry I missed this post before.
Once the system is pressurized there won't be a delay until it bleeds enough air for the compressor to kick in.
