Donor Flywheel
Santa Fe, New Mexico
A local Mudder needs a clutch. I thought that I would lend a flywheel for the install, so it can be machined before the old one is taken out. This is for an early-type clutch set-up, usually associated with 3-speeds. Is the part number correct?
The step between the clutch bolting surface, and the disc friction is 16.10mm. The step between the disc friction and the crank bolt surface is about 12.20mm.
The thickness of the flywheel where it bolts to the crank is 10.92mm.
After I clean it up a bit, I can get a visual on the glazing, as it has been used since it was last machined.
@Cgn1976
As the potential recipient, I figuered I'd better do some digging! I found this on FJ Parts listed as the 3 speed 58-74. Hard to read but apears to be the same number 13451-60010.
