- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
Dunno, I only use USA Hastings chrome rings.
Stick to the service manual specs on those rings - aftermarket rings are commonly off a bit and I don't give ***** what the machine shop claims as to lapping rings in a controlled manner to make them all identical - I always check ring gaps . Rebuilding my last Suzuki engine took 5 separate kits to get a set that fit all 4 pistons - it's rare to see one of those engines hit the magic compression pressure specs , that one was dead-nutz on spec at 200psi cold , perfect . I always had to fight with customers and rebuilt engines that were broke in properly and were well below wearout spec in the service manual (170psi) - it results in a weak engine that my carb setups could never help . Telling them their new engine was junk produced some serious Sh** Storms with the rebuilders , some of them reputable vendors from out forums . It's all about paying attention to those specs and stick to it - otherwise you'll regret it later with an engine that is either weak , burns oil or won't last nearly as long as it should .
Ok , rant off....
Sarge
