- Joined
- Jun 26, 2011
- Threads
- 4
- Messages
- 8
With the dome light set to go on and off when the door is open/closed the light remains on (along with the light on the door) when the door is closed. The dome light can be turned off if changed to the off setting; however, the door lights remain on. In addition, the 10 second delay when the key is turned off, that lets you put the window up or down doesn't work either, but the window switch works when the key is on. Every once in a while (random) everything works as it should, but 90% of the time it isn't working. I've changed the dome light out and fiddled with the door switches to no avail. Any help??
