- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
February 7, 2014 – Auburn, WA*– Vision X Lighting continues to expand it’s*work-duty*line-up with the new Duralux Series LED lights. Designed with fleet vehicles and working professionals*in mind, each light combines durability and*affordability*for many*on-the-job lighting needs.*Available in 4 or 6 LED and 40 or 60 degree beam configurations, each light provides outstanding distance and*more light […]
The post Doing Work with Vision X Lighting’s Duralux LED Series Lights appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
February 7, 2014 – Auburn, WA*– Vision X Lighting continues to expand it’s*work-duty*line-up with the new Duralux Series LED lights. Designed with fleet vehicles and working professionals*in mind, each light combines durability and*affordability*for many*on-the-job lighting needs.*Available in 4 or 6 LED and 40 or 60 degree beam configurations, each light provides outstanding distance and*more light output than a 100 watt halogen light. *Each Duralux*light only draws*a mere 1.6A (12V) from it’s 5 watt premium LEDS, reducing*power consumption, leading to fuel savings and lower operating costs. The*rugged die-cast aluminum housing provides superior protection against the elements, and the universal single-bolt mount allows for a great range of adjustment. Each light is backed by the Vision X Lighting Extended Warranty for added piece of mind. For more information visit*www.visionxusa.com*or call 888-489-9820.
Duralux Series*Features:
Technical Data DURA 440/460</p>
Technical Data DURA 640/660
Related posts:
Link
Related posts:
- Vision X Releases New UM Round or Square LED Work Light
- Vision X Lighting Releases a New Generation of Solo Pods
- Vision X Lighting introduces Bolt On Light Mounts for ’07-’14 Jeep Wrangler JK
February 7, 2014 – Auburn, WA*– Vision X Lighting continues to expand it’s*work-duty*line-up with the new Duralux Series LED lights. Designed with fleet vehicles and working professionals*in mind, each light combines durability and*affordability*for many*on-the-job lighting needs.*Available in 4 or 6 LED and 40 or 60 degree beam configurations, each light provides outstanding distance and*more light output than a 100 watt halogen light. *Each Duralux*light only draws*a mere 1.6A (12V) from it’s 5 watt premium LEDS, reducing*power consumption, leading to fuel savings and lower operating costs. The*rugged die-cast aluminum housing provides superior protection against the elements, and the universal single-bolt mount allows for a great range of adjustment. Each light is backed by the Vision X Lighting Extended Warranty for added piece of mind. For more information visit*www.visionxusa.com*or call 888-489-9820.Duralux Series*Features:
- Available in 40° and 60° Beam Pattern
- More Light than a 100W Halogen
- Low Power Consumption,*as low as*1.6A (12V)
- 50,000 Hour LED Lifespan
- Die-cast Aluminum Housing
- Weatherproof Deutsch Connector
- DURAE440 -*Available with E-Mark Approval
- Warranty: Extended
- Raw Lumens: 1,972
- Effective Lumens: 1,380
- Wattage: 20
- Weight: 1.50 lbs/0.68 kg
- LED Lifespan: 50,000 hours
- Dimensions: 3.94” x 2.57” x 4.24” */ *100 mm x 65.5 mm x 107.6 mm
- Input Voltage: 11-65V DC
- Amp Draw: 1.67A
- IP Rating: IP-68
- Vibration Rating: 8.6g rms
- Operating Temperature: -40° Celsius ~ +80° Celsius
- Raw Lumens: 2,958
- Effective Lumens: 2,071
- Wattage: 30
- Weight: 2.10 lbs/0.95 kg
- Dimensions: 5.39” x 2.57” x 4.28” */ *136.7 mm x 69 mm x 106.5 mm
- Amp Draw: 2.5A
- IP Rating: IP-68
Related posts:
Link
