Doing the Oil Pans
I almost have the no. 1 oil pan off. Been bleeding pretty heavily from the rear pan arch. Been taking my time so I don't mess anything up.
The lower oil pan was a pain to get off. Used heat and a utility knife blade to loosen up the old fipg. Took a bit of time but it finally gave way.
Still have yet to get two accessory attachment bolts off of pan no.1. Once I do that I will have to fight to get that pan off. Using an overhead lift to pull the engine up an inch or so.
When I took off the oil level switch, something did not look right (even though I have never seen one). Looks like part of the float is broken off. Did not see any bits coming out with the oil, so it could be old damage. Did find a few flakes of metal on the oil sump screen. Am sending Blackstone Labs a sample of the blood tomorrow.
What the oil level switch looks like. Anyone know the part number?
CDan (aka cruiserdan) here on MUD...
Look him up, send him a PM, and he can get you what you need for a great price :)
yeah, mine was the same way when my front crankshaft seal and oil pump seal went. the effect was to get weird intermittent "Low Oil Level" light on the dash (which I think just is the "OIL" idiot light). the black plastic is really brittle after sitting in the oil that long I guess. It was pretty affordable as I recall and just the tow bolts holding it in it was a 5-min job to replace. I actually ran my bad one for a few days while waiting on the new one since I knew the oil level was ok.
