- Joined
- Sep 23, 2003
- Threads
- 356
- Messages
- 2,573
I called a local shop (new) and was a bit surprised by the price to descale a frame with garnet abrasive. Doing the axles would be extra. I thought this was cheaper.
ya see that was i was thinking.all my years of blasting s*** is exspensiveI would not even start my compressor for less than $250. What you have to understand is the cost of all the equipment to do these "small jobs". Go and rent everything and then tell me when you hit that $300 mark....![]()
ya see that was i was thinking.all my years of blasting **** is exspensive
ya I did my own. for free 99....Gee I'm sorry that you guys pay so much for sand blasting $125.00 is the price that I got and his work is recomended.![]()
you look like a painterya I did my own. for free 99....
notice the quality of the crappy pic. I have a shot of me doing the blasting...you look like a painter![]()
blasting a frame that is still on is a situation where to many things can go wrong. I would not attempt it myself. Think of all of the sensitive areas.... That could get abrasive inside. When I blasted my frame I put it on 55gal drums, and blasted it also removing some undercoat with silica no prob. As far as doing a good job. I am assuming a small fraction of these members know what they are doing with this application to be proficient at it. I think there is a guy in W.V that would agree with me.I notice in the pic above the body/tub is obviously off the frame. Do you think cost would go up for blasting a frame that has the body on it? And can they still do a decent job with it on the frame? Thanks.
yea its a bitch, ya got to know what gets hurt, must know your eguiment, such as valves and air pressure, along with what materials you are using. and when the body is on the frame so much not gets done that trully needs it.blasting a frame that is still on is a situation where to many things can go wrong. I would not attempt it myself. Think of all of the sensitive areas.... That could get abrasive inside. When I blasted my frame I put it on 55gal drums, and blasted it also removing some undercoat with silica no prob. As far as doing a good job. I am assuming a small fraction of these members know what they are doing with this application to be proficient at it. I think there is a guy in W.V that would agree with me.
I did my axles as well with TONS of duct tape covering the ends, and the drive shaft area.
https://forum.ih8mud.com/showthread.php?t=99015&page=2
good pic in my build up thread
I actually finally found the pic I wanted to put up here. The PROPER way to begin frame prep work.yea its a bitch, ya got to know what gets hurt, must know your eguiment, such as valves and air pressure, along with what materials you are using. and when the body is on the frame so much not gets done that trully needs it.![]()
