does this sound like a battery or connection problem
Colorado m'fing Springs!
TOday we finally got some rain down here. Considering every thing is about dead and dried up i got school girl excited and decided i wanted to go drive in the rain/mud.
So just stopped at the house real quick, ran inside for 20 minutes then jumped back in the cruiser, turned the key and nothing. Like the lights had been left on all night and battery completely drained, it would light up the panel dimly and on key turn it would die out.
Popped the hood and banged connectors, tried again and it seemed to be a little better. Got my 10mm wrench and tightend connections, which were not loose and it fired up, everything reset:radio, ecu.
Obviously points to connections but pos side is all new from oem terminal to fuse links. neg is tight and clean. I do get a small amount of acid build up on pos side though. Is this the sign of a dying battery or something else?
EDIT TO ADD ANOTHER?: Why does my a/c squeel like a pig during start up after getting wet? is this normal or do i need to check something?
sorry for being a :wrench: noob but hey, im learning
Most battery shops will test your battery for free.
forgot about that, duh. I was just curious if these are symptoms of a bad battery b/c im planning a 3k mile road trip end of the month.
Very well could be. My first thought was dirty connection, I would clean them again (even if they look clean) and check it. A local mudder to me had a similar issue, thought his battery was shot. His pops cleaned up the terminals, and it fired right up. No acid build up at all on either one, so visual inspection passed.
Free and quick. Worth a shot.
the other side of the negative terminal. check your ground. It may be a bad connection.
about the a/c... Change the belt and it will probably stop..
How old is the battery?
Got a multimeter? Next time (if there is a next time...), measure the battery voltage right on the lead posts while a helper tries to crank the engine or just turn on the headlights on highbeam. If the battery voltage remains good, then you know it's not the battery but instead something else.
Like others have written, would pay to remove the battery clamps, clean the posts with a post cleaner AND clean the inside of the battery clamps too and then tighten it all back up. I recently put a new main battery in my 80 and a few weeks later had a similar issue (no start, dim lights etc), I just hadn't tightened the ground clamp sufficiently.
On your belt squeal - check the tension on the various belts, your A/C one may be a little loose.
cheers,
george.
after i clean battery terminals, i usually take a knife and scrape a thin layer of the metal off to have some nice fresh contacts. i would still get the battery tested as we've had quite a hot summer already and temps affect batteries more than anything else.
will do, thanks guys!
