I broke this off my radiator this afternoon. It is a pressure line I am assuming going to the engine block. I want to try and drill and tap a brass fitting there and reconnect the hose. I am about to flush the entire cooling system anyway.
^^^^^^SO TRUEAnd next time don't lean down on the top of the radiator for crying out loud!
You will gush coolant from the nipple if it breaks. But it won't take long to release the 13-16psi of pressure, and you will smell it. Turn the engine off, get your 5 minute JB Weld out. Reweld the nipple, get off the mountain. You probably won't even lose enough coolant that you couldn't get down without refilling the rad. Or jB weld the hole from the nipple. If I'm not mistaken that is the hose that goes to your throttle body. Not important on a mountain in the Carolinas.
If you have the money to buy a radiator today, save it for tomorrow. Tap your nipple, go a few more years on your current radiator.
But you did say you had rust... But that is likely coming from your block. It would be a shame to get rusty all up in your new radiator.
