Does this look infected???
Denver Colorado
Hey guys, I was just wondering if this looks like something I need to address immediatley? It is right up near the firewall, and is attached to the heater control?? It has been there for a month or so and has not seemed to grow any worse. I also am wondering if it is okay to use a "chemical" flush like the ones at oil change places to do a rad. flush and fill. The service manager at one place told me that the flushes can actually do more harm than good. What do you think??? I would do it myself, buy I am in an apartment for the time being, and have nowhere to wrench on the 80... Usually the flushes run about 100 bucks which doesn't seem bad to me.
Cheers
Cheers
looks like it is leaking and needs the hoses replaced. Keep an eye on your radiator and see how much fluid you are losing.
Eeek! The only reason I can think of for it to leak right there is if the hose or the pipe is in trouble. And if that hose looks that bad, I be on the PHH as quick as possible. Looks like you got something funny going on with your coolant, so flush it, pull those hoses that you pictured, and replace the PHH.
most vehicle specific coolant is designed to build up like what you are seeing when there is a leak. the hoses are seeping and will probably leak worse later down the road. if the coolant is not exposed to the air it doesn't really do what you are seeing. some coolants are designed with natural ingredients and if you use regualar water, it will break down the coolant and clog up the system. Your fix is easy, just remove the factory clamps, remove the hoses, check the hoses, make sure they are not hard or torn, clean the plastic valve and reinstall the hoses with worm style clamps.
