Does the FJ come in a full time 4wd model?
manual IS fulltime 4WD............torsen/locking center
automatic is part time 4WD
The manual transmission models also come with the rear diff lock as a standard feature, unlike the automatics ;)
The rear diff lock is available for the automatics so its not an issue in either. The buyer just has to be smart enough to make sure the FJC they are buying has the rear diff lock installed...
The rear diff lock for the automatics used to be part of an upgrade package in Canada, although it is now a standard feature on both transmissions.
Best way to check is the same as on an 80. Stick your head under there and look at the rear axle ;)
Wouldnt it be easier to just look for the button.......or read the window sticker thing:meh:
or maybe just look at the Tcase, it wil say Hh all the way back closest to you!
??? :confused:
I thought we were talking about the rear locker? If I were buying something used, I'd crawl underneath to verify. There have been a couple unscrupulous sellers who just plugged switch blanks with switches but had no locker. There are wires with connectors there but without the locker, it won't work (obviously)...
If you're buying new off a Toyota lot, yes.
??? :confused:
X2 on checking it out when buying used. I seem to recall a couple incidences in the 80s section of buyers getting a fancy switch with nothing to back it up :doh:
