Does a part number exist ?
Giza, Egypt
Found out why I get no wiper fluid for the rear washer, is there a OEM part for tube ?
It's for an 1997 FZJ80L with barn doors.
Thanks for the input.
85372RHOSE, REAR WASHER (FROM JOINT TO JOINT OR NOZZLE)
90099-33080L=6901$8.30
90099-33299CUT HOSE TO LENGTH AS SPECIFIED IN REMARKS, L=30, NO.31$7.55
90099-33683L=3350, NO.11$10.36
90446-06013CUT HOSE TO LENGTH AS SPECIFIED IN REMARKS, L=240, NO.5, RH1$6.64
90446-06292CUT HOSE TO LENGTH AS SPECIFIED IN REMARKS, L=2090, NO.41$20.60
90446-07001CUT HOSE TO LENGTH AS SPECIFIED IN REMARKS, L=600, NO.5, LH, NO.6, RH1$7.59
85373-60010*** STD. PART$4.27
85373RHOSE, REAR WASHER (FROM JOINT TO NOZZLE)
90446-06013CUT HOSE TO LENGTH AS SPECIFIED IN REMARKS, L=280, RH, LH1$6.64
But surely a dealer doesn't need a part number from the customer when he has his own parts diagram? This tube is common to other landcruisers like the 7* series and probably the 60 series.
Thanks RoscoFJ73, I had a feeling someone from "Down Under" would be more familiar with our barn door models.
I think it would be 85372RHOSE, REAR WASHER (FROM JOINT TO JOINT OR NOZZLE), do you concur ?
G'day
Yes, it looks like that bit. Buy a metre of it and hide it in the doors for the next one to spring a leak. My 73 series washer hose snapped in exactly the same spot. I guess it has a 20 year life span
