Dobinsons 2.5" Lift parts list.
I'm getting ready to order Dobinsons lift kit parts. Does this setup look correct for a 2.5" lift running 33s?
The truck is non-KDSS and will be driven mostly on-road. My primary goal is to maintain good ride quality while carrying around 200 lbs of cargo in the rear. I want to be sure that I am matching the correct Dobinsons parts.
Any input would be appreciated.
  • Front Struts: Dobinsons Twin-Tube Front Struts (Standard Seat Height) | GS59-221 — $175.00 each ($350.00 pair)
  • Front Coils: Dobinsons Front Lifted Coil Springs (2.5" Lift, Stock Front Weight) | C59-314 — $300.00
  • Rear Shocks: Dobinsons Twin-Tube Rear Shock Absorbers (Medium/Heavy Valving) | GS59-701 — $115.00 each ($230.00 pair)
  • Rear Coils: Dobinsons Rear Lifted Coil Springs (200-400 lbs Constant Weight) | C59-327 — $350.00
other parts
  • CV Axles: CVJ High-Angle Axle (OEM Steel Core, Red Silicone Inner Boot) | 9808 TR — $328.00 each ($656.00 pair)
  • Brake Lines: Crown Performance +2" Extended Front Stainless Steel Brake Line Pair | L-T120-F2 — $90.00
Hardware & Geometry Adjustments​
  • Conversion Kit: MetalTech 4x4 Zero-Lift Rear Airbag-to-Coil Conversion Kit (Stage 1) | MT-GX470-S1 — $99.95
  • Upper Control Arms: JBA Offroad Standard High-Caster UCA Pair | JBA-UCA-4R-05 — $560.00
  • Panhard Rod: Icon Vehicle Dynamics Heavy Duty Adjustable Rear Track Bar | 54200 — $402.00
  • Differential Drop: Dobinsons Front Differential Drop Kit | DD59-527K — $65.00
  • Sway Bar Drop: Dobinsons Front Sway Bar Relocation Kit | SE59-524K — $45.00
Total (Components + Shipping): $3,250
